Vellum constraint issue
   590   0   1
Hi. I got a problem with vellum constraint settings:
if i write quite simple vex code in two seperate nodes to control restlength, it works well.
but if i write same code in one node(just by group selecter in geomwtry wrangle code), the result was different.
Could someone explain this? thanks very much.
The attached hiplc will point you the preblem.
vellum_issue.hiplc (481.0 KB)
