match size weirdness
   516   0   1
I have noticed a strange behaviour with the match_size node.
If i use it without a secondary input geometry it suposedly use a 1*1*1 bounding box to do the justification, but when I in put a 1*1*1 box in the secondary input it does not give the same result ????
In the case with no geometry attached it seems that the blue guide geometry is moving depending on the settings of the nodes
Capture d'écran 2024-01-21 163254.png (247.4 KB)
Capture d'écran 2024-01-21 162558.png (153.6 KB)
Capture d'écran 2024-01-21 162422.png (106.4 KB)
