How to select Cone Twist Constraints in the viewport?
   1256   3   1
I've loaded an example file from the help pages which uses the RBD Cone Twist Constraint Properties sops node.
When I select the RBD Cone Twist Constraint Properties node and hit return in order to make edits I am told to select one or more constraints.
No matter where or how I click in the viewport I am unable to select or deselect any constraints whatsoever and I've been unable to find any information on how to actually select one of the existing constraints.
I can use the command Ctrl+A to select all constraints, but then there is no way to deselect them again.
Maybe there's a bug in here somewhere, but I would've imagined that you could just click on a constraint to select it and click off it to deselect it.
Edited by benek - 2024年5月23日 02:07:50
Screenshot 2024-05-23 at 07.01.31.png (1.6 MB)
OK… so I figured it out … you have to toggle the Secure Selection button.
Screenshot 2024-05-23 at 09.39.59.png (7.5 KB)
you can try to setup different Groups
in my example
Group 0 1
Group 2 3
スタッフ
benek
Or hold down "S" key and select the constraints you're after.
