hi, i have a VAT-like system where i need to bake out position data kinda like vector displacement.
i'm using labs maps baker and tried a custom attribute bake, but the EXR data is clamped (at least the negative values are).
i tried using the vertex color (Cd) option but same results.
from what i understand, just by using a HDR format like Exr is sufficient for the baker to output correct data (i.e: 32 bit float).
when opened in PS the file is indeed 32 bit but the negative values are not there.
looking at the data in houdini spreadsheet i see that it is correct both in terms of type of data and the values (negative values and above 1).
does anyone have any idea why this is happening? am i missing something?
there is a merge node that throws a warning something about attributes not being initialized properly but checking the data before and after the merge node i see no difference...
Baking position data to EXR is clamped/LDR
483 2 0- staicu.teodor.23
- 12 posts
- tamte
- 8730 posts
- staicu.teodor.23
- 12 posts
yes
looking at the nodes inside maps baker it seems they are normalized even if they are not "clamped" by the filetype. there's also a convert node in cops for all maps that converts to 16 bit for some reason. i guess it makes sense for games that 32 bit textures are overkill, but what if you want to bake out something more precise like position or normals...
i need to evaluate if i really need the HDR values or if i can accept the loss of precision, else i need to "gut" the baker or make my own.
