PolyBevel Drag-LMB to change distance doesn't work sometimes
   392   2   0
I'm experiencing a very weird bug. When I put down a PolyBevel SOP and enter its viewer state, the LMB-drag doesn't work. Other shortcuts, such as Shift+LMB to add an edge to the beveled group, and scroll to change divisions, work perfectly. Only LMB-drag to change distance doesn't work.
Even more weirdly, it sometimes fixes itself. If I switch to another application, then switch back to Houdini, this issue usually goes away.
I've reported this to SideFX, but they couldn't reproduce it.
Anyone experiencing the same thing?
Screenshot 2024-06-29 021824.png (504.5 KB)
I had this exact same issue on an older versions of Houdini but haven't experienced it at all recently.....currently using the daily build. 20.0.735.
I've tried both 20.0.735 and 20.0.751 but both suffer from the same issue.
As for a workaround, I've found that if I open context menu and close it again (RMB twice) it fixes itself for some reason.
