PolyExtrude 2.0 inset works like this:
As you can see there are some weird topology distortion around the edges.
The old PolyExtrude works like this:
Edges flow nicely.
How do I get the old PolyExtrude behavior in PolyExtrude 2.0?
PolyExtrude inset cause weird distortion
728 5 0- kodra
- 373 posts
- EZiniT
- 53 posts
Interesting.....deserving of an RFE maybe.
Doesn't immediately look like there is an option to get the same outcome on the new 2.0 node itself.
A workaround/chore to get the same result is using an edit sop to straighten selection of the edges after the fact.
There is also the "edge straighten" node to accept a group which does the same thing more procedurally.
- kodra
- 373 posts
- Mike_A
- 253 posts
- justin_bisceglio
- スタッフ
- 50 posts
- kodra
- 373 posts
