Hi everyone,
I want to save the initial position (restlocal) of some of my joints to create a constant offset. I currently do that in vex by simply creating new nodes with the restlocal copied in a detail wrangle. Afterwards I use an autorigcomponent to connect all the needed wires.
Is that possible with a stash node and if so, how to use the stash node in conjunction with the autorigcomponent?
Any help would be awesome.
Cheers!!
how to save a static rest matrix in apex
398 2 1-
- mmassloh_houd
- 8 posts
- william_harley
- スタッフ
- 48 posts
mmassloh_houdWhat are you looking to stash? You can adjust the skeleton and pipe it in as a reference skeleton like we are doing with the guide skeleton. You could also set up the offsets on the guides skeleton to make things a little simpler.
Hi everyone,
Cheers!!
- mmassloh_houd
- 8 posts
