BUG: The opproperties help is wrong (9.0.719) in that the order of specifying things is wrong (you specify the operator first).
Q: After figuring out the order, it wouldn't add a vm_volumefilter to an Object, it complained that it only should go on a SHOP. -f “force” works fine so not a problem but curious if this was an error or not since it's clearly valid.
RFE: Expose the very useful filters to the Rendering Parms UI!!
peter B
Q and BUG: opproperties Hscript command
2423 0 1- pbowmar
- 7046 posts
