I'm trying to dynamically break the weld contraints that you see in the first image. It should be like a cut, opening from left to right. I have animated the curve I used for the break to dinamically transfer an attribute (something like @weld = -1) but I realised that it doesn't work if I do that before the SOP Vellum Solver, because it doesn't update it. So, I tried to do it inside the Vellum Solver using a SOP Solver, but I'm not sure how to connect it properly and I keep getting errors.
Thanks in advance.
Houdini Vellum - break welds dinamically
377 1 0- AlbusNolente
- 19 posts
- tamte
- 8753 posts
