Copernicus: How to render multiple texture maps easily?
   1058   5   1
Hi
Looking at new cops and I can't figure out how to render our maps based on "channels".
I was hoping I could render diffuse, normal, height etc each as individual textures by inputting them to a node (something like the preview) but it seems like I'd need to create a new rop image output for each map.
Is there an easier way to do this or is that the only way?
Using "collect" node, you can bake multiple layers into one .exr file, but it isn't really a solution, multiple image output is necessary.
Edited by Karlis Stigis - 2024年8月5日 03:01:07
Screenshot 2024-08-05 085936.png (196.4 KB)
always learning
maybe hda or recipe ?
Just throw down a Null you can see more here:
https://www.sidefx.com/forum/topic/97376/ [www.sidefx.com]
PHENOM(enological) DESIGN;
Experimental phenomenology (study of experience) is a category of philosophy evidencing intentional variations of subjective human experiencing where both the independent and dependent variable are phenomenological. Lundh 2020
Thanks but I wanted to be able to render to tif
I can build my own node in TOPs which has a workitem attr for the `port` and it wedges over those, but it's kind of round about way of doing it.
Would be cool if maybe there was a $PORT or something within the ROP that let me point to a COP node and write separate tif/png/jpg for each port/aov.
Karlis Stigis
Hi Karlis, after my tests it fails.
As you can see, the channel 'a' and 'b' are RGB, the channel 'c' is mono. after I click Render, I got a .exr file with black color, the size only 194KB, no matter I able or disable Single Output.
Sorry, I was wrong.
I can see the AOV correctly after trying to open the .exr file with MPlay.
Edited by Under_Pressure - 2024年10月24日 02:05:27
