I am surprised to not found a clear explanation on how to instance a tree with instanced leaves in solaris usind USD and the component builder.
if I was on Maya I would use a arnold ASS file and instance the job would be done in 3 secondes. now I am struggeling a lot using solaris for something so simple. Solaris feel like reinventing the wheel sometimes.
my tree have instanced leaved, I use a component builder(native instances) to make a usda then load this usda with a reference and plug it into a instance node but it doesnt render but freeze houdini, using arnold. any tips?
tks
instance tree solaris
808 4 0- Foocus
- 11 posts
- Siavash Tehrani
- 729 posts
- Foocus
- 11 posts
thank you for you reply,
I did the tree with the tree generator so it already come with instanced leaf node.
1. how to import a tree who already got instance into the component builder(internal sop > object merge/lopimport ?) with point instancers method
2. my problem comes when I want to instance this tree again(who already got instanced leaf method) to create a small forest.
the classic way of creating a componend builder>select a external sop>sselect the sopcreate output > methode point instancer then plug it into a instancer node work with renderman but not with arnold(it work 1 time out of 100 for a reason I dont know), any idea ?
thanks
thanks
Edited by Foocus - 2024年8月4日 06:37:30
- Siavash Tehrani
- 729 posts
- Foocus
- 11 posts
