why mtlxsurface not support transmission depth
   Views 1294   Replies 9   Subscribers 1
which version are you using? It should be supported since 20.0.246
20.0.246
Added support for transmission depth in karma CPU and XPU implementation of Mtlx Standard Surface.
Mon. February 6, 2023
FX Supervisor
Method Studios, NY
スタッフ
For the MtlxStandardSurface, under the "transmission" tab...
  • these 5 work: "transmission", "color", "depth", "dispersion" and "roughness"
  • these 2 do nothing: "scatter", "anisotropy"
So depth does work (we call it "absorption"). But one gotcha is the automatic-fake-caustics (ie transparent shadows) can reduce the effect. One possibility is to disable it, or to tweak the "Fake Caustics Opacity" setting. The attached example shows depth/absorption working with fake caustics disabled.
absorption_test.hip (471.0 KB)
tamte
20.0.246
Thank you for reply ,yeah , the transmission depth works , but the transmission scatter color not support yet?
brians
thank you for detailed reply , it helps
スタッフ
happybabywzy
No, because that would make it a volume.
The current workaround is to duplicate the geometry and make it a uniform volume.
brians
happybabywzy
Hi Brian, are there plans to eventually support scatter?
Siavash Tehrani
+1 Also curious when/if this will be supported.
スタッフ
freshbaked
Yes eventually, but at the moment we have higher priorities
brians
Sounds good, thank you.
