Camera Physical Lens / Tilt Shift
   732   5   1
I cannot get the Tilt Shift to work.
All other effects work, even the offset x and y under the tilt shift tab, but the tilt shift itself does not work.
This scene is made in Houdini 20, but I tried it in Houdini 20.5 with the new Lens Material (camera) and it's the same...
Am I doing something wrong ?
Cheers!
Alain
tilt_shift.hiplc (1.2 MB)
which isn't working, the tilt or the shift?
the tilt is not working...
Thank you.
Alain
スタッフ
Hi Alain, you will need to enable some depth-of-field (i.e., set an f-stop value) to see any effect of tilting the lens.
Hi Rob,
Sorry for the delayed answer.
It did'nt work for me.
The only way I could achieve a tilt was to put x rotation to 0 and then playing with the "Vertical Aperture Offset" in the View tab from the camera...
Tomahawk-573
Hi Rob,
that is a "shift". a tilt affects the orientation of the plane of focus, not the geometry of the image.
