Well, it seems that either UV Layout SOP or Match Current Definition has a beef with me. I'm not going to speculate which one of the two is the culprit, so I'm just going to describe the problem that I'm experiencing in the current production build (20.5.278).
The video depicts my antics with UV Layout SOP nested in an HDA. Newly created UV Layout operator works fine, but once the asset is saved and its definition is matched, UV Layout SOP breaks. What is weird is that a copied instance of that very same operator repiped to the flow works just fine. Until of course I save and match the definition of the asset. Also, the malfunctioning UV Layout SOP "fixes itself" after the scene containing the asset is reloaded. Of course until I save the definition...
I'm sorry, but even though I consider features implemented in 20.5 to be of huge significance (Copernicus, MPM), I feel that I'm spending most of my time fighting bugs and restarting the program.
My "UV Layout" and "Match Current Definition" woes
767 6 1- ajz3d
- 548 posts
- ajz3d
- 548 posts
- justin_bisceglio
- スタッフ
- 50 posts
- ajz3d
- 548 posts
- ErikHallberg
- 15 posts
- ErikHallberg
- 15 posts
- ajz3d
- 548 posts
I reported this bug yesterday. Its ticket number is #156601.
To sum up:
Contrary to my original belief, the bug is not caused by "Match current definition" in any way, but by "Stack Identical Islands" of the UV Layout SOP itself.
The bug can be reproduced with just a Box, UV Unwrap and UV Layout SOPs piped together in this order. Enable "Stack Identical Islands" and the UV Layout breaks and becomes beyond repair. And what I mean by this is that the operator will no longer react to changes of its parameters. Unchecking this flag doesn't fix it. Duplicates of the broken node work, until I enable "Stack Identical Islands" (at this point they'll break in the same way). It's reproducible 100% of the time.
The only remedy is to delete and create a new instance of the UV Layout SOP.
Both 278 and 332 production builds are affected. I also tried running Houdini with default user preferences, to see if perhaps there's some interference coming from external packages, but UV Layout still breaks.
I'm on GNU/Linux BTW.
To sum up:
Edited by ajz3d - 2024年8月26日 07:36:59
