Karma huge memory leak when rendering through ROP
   318   0   0
I started using Karma lately and today I came across a problem I can't seem to solve.
I'm trying to render a sequence of a pretty simple scene but once the frames start rendering the RAM usage starts increasing and goes up every frame until it reaches my system limit (32GB), slowing down everything. The fact is the first frames are rendered without problems using 70% of my system ram, but give it 10 frames and it will rise until it reaches the limit. It looks like karma is not purging memory from past frames and instead keeps adding on top of that. An idea might be the motion blur node I used, but I doubt
This is not normal, right?
Maybe it has been already logged but I couldn't find any help on the forums
I am using H20.5.278
UPDATE: I found the problem, it's the motion blur LOP, with that node turned on the memory keeps rising.
I'll log it.
Edited by william-or - 2024年9月9日 18:13:59
