Labs Substance Material
   358   0   1
I cannot get the Labs Substance Material to function at all. When I create the node in a Geometry context I get the following error copied below. And when I try to load an sbsar file I get the Traceback copied below.
I'm on MacOS Sonoma 14.6.1, Houdini 20.5.332, Labs 20.5.332.
Any help at all would be greatly appreciated!!
Error: Bad node type found: labs::sbs_archive in /obj/geo1/substance_material1/copnet.
Warning: Skipping unrecognized parameter "file".
Skipping unrecognized parameter "reload".
Skipping unrecognized parameter "sizemenu".
Skipping unrecognized parameter "substance_parms".
Skipping unrecognized parameter "name_image_plane_from_usage".
Skipping unrecognized parameter "scopergba".
Skipping unrecognized parameter "pscope".
Skipping unrecognized parameter "fscope".
Skipping unrecognized parameter "frange".
Skipping unrecognized parameter "fdropoff".
Skipping unrecognized parameter "fdropfunc".
Skipping unrecognized parameter "foutside".
Skipping unrecognized parameter "flist".
Skipping unrecognized parameter "fmenu".
Skipping unrecognized parameter "fautoadjust".
Skipping unrecognized parameter "currange".
File "labs::Sop/substance_material/file", line 1, in <module>
File "labs::Sop/substance_material, PythonModule", line 31, in reload
AttributeError: 'NoneType' object has no attribute 'pressButton'
