Vellum Weld issue
   174   0   0
Hi All! My first post here. I'm a Houdini and Vellum noob.
I have a issue regarding vellum welding. I'm making a scene were two pillows collide with each other, the problem comes when using two vellum cosntraint weld for welding two different objects, one for each object. Both objects try to weld together but I want them to weld separately.
I notice that when using stitch to points on one object insted of welding on both, the problem is solved, but I want to add more objects and i prefer weld rather than stitch.
Each object has an attribute to guide the welding for each object, I tried also unable Close To points, distancing objects but nothing solves my problem.
I attatch my issue, what I want and a hip file.
English isn't my main language, so sorry in advantage. Thank You!
HipFile.hipnc (898.5 KB)
