tarted learning houdini and working on a flip simulation and came across this issue where at a certain number of frames the whitewater solver works perfectly fine but if i go less than the 87th frame it suddenly disappears and then i get this error.
Error
Invalid source /obj/Fx_Layer/whitewatersource1/use_extra_sources.
(Warning: Bad node reference: "" in parameter /obj/Fx_Layer/whitewatersource1/use_extra_sources/expr1.
Error: Invalid source /obj/Fx_Layer/whitewatersource1/emit_s.
(Error: Either found no valid input VDBs, or found input VDBs with differing transforms.).).
attached is an image as well as a video of whats up with the sim
