Hello, may I ask if I have made two drawings of the fabric on the Vellum system, but when I finally entered the simulation, only the drawing Pin constraint effect of the first fabric could be applied. I don't do anything else, just switch the merge order of merge 2, and the drawing Pin constraint effect of the second block can be effective. Why can't the Pin constraint effects of two fabrics be effective at the same time?
Here is my simple file example
May I ask why the constraint operation on two fabrics on the
200 0 0- hair_K
- 1 posts
