When a particle is generated,
how do I know at which frame it was generated? How can I save the frame number as a particlae attribute?
I read online that it says to use @age==0 to determine this,
But I found that once the particle is generated, @age is greater than 0, there is no such thing as @age equal to 0.
So I can't tell if the particle is generated in this frame or not.
As an example:
I want the particles generated after 20 frames to turn red, not @age at a certain value,
how can I achieve it?
At which frame particle is generated?
582 4 2-
- jackdon4682
- 22 posts
- protozoan
- 1772 posts
- Tanto
- 503 posts
- jackdon4682
- 22 posts
- jackdon4682
- 22 posts
