I have a network of nodes in an asset and inside it there are a lot of resource intensive operations like converting to VDB SDF and back.
And all this takes up a lot of space in RAM. I would like that after the entire network in the asset is executed, only the result of the asset remains in RAM. I thought that if I put all the contents in a compiled block, then after cooking the network, the RAM will be freed, but this does not happen.
Is there another way to solve my problem?
Reducing the amount of used RAM using compiled blocks
225 0 1- Alt_stage
- 20 posts
