material X BSDF nodes and Karma XPU
   324   4   0
I'm trying to make materialx BSDF shader. But cant make it render with XPU. Works fine with CPU.
I have: mtlxoren_nayar_diffuse_bsdf >> mtlxsurface1 >> mtlxsurfacematerial
and then assigning mtlxsurfacematerial to mesh. as I said renders with CPU fine but XPU fails to default grey. Tried collect node instead of mtlxsurfacematerial - same result.
Are there extra steps needed to make materialx BSDF nodes to work in XPU
Not supported in XPU yet, as per the docs.
freshbaked
Thank you! May I ask where in the docs did you find the answer? I was looking in the help card to the nodes didnt see mentioning of it
スタッフ
“Does not support MaterialX pbr nodes”
https://www.sidefx.com/docs/houdini/solaris/karma_xpu.html#materials-shading [www.sidefx.com]
tayga
freshbaked
https://www.sidefx.com/docs/houdini/solaris/karma_xpu.html#features [www.sidefx.com]
