Rendering white water with ocean procedural and Karma XPU
   268   0   1
I'm not sure about the correct way to render the white water in Karma XPU and houdinioceanprocedural LOP. Do you export the particles in the whitewater_import using the cache node and import it under "Shading -> Foam Particles"?
So left branch with the null node and the "render" flag are not used at all if you render using houdinioceanprocedural?
