Convert SOP asset to equivalent subnet
   136   0   0
Hello everyone!
I have already tried a lot of things and realized that the only solution to my problems at the moment is to convert my SOP asset back to subnet while preserving the parameters.
I see 2 ways
1) (Not working) RMB on the asset -> Actions -> change type, check the boxes: Keep name, Keep parameters, Keep asset contents.
This method does not work, because only the parameters that have connections are saved (highlighted in green) and even then it turns out very crooked. And if you transfer the parameters manually, it loses all meaning.
2) Write and debug a script in Python (I hope there is a simpler way)
I need to convert a number of asset instances, so I am not considering manual transfer.
Please tell me how else to solve this problem.
P.S. I understand that the subnet does not have many properties of assets, but the asset for conversion is technical and is arranged relatively simply, so the correct transfer of parameters and their values ​​(along with expressions) will be enough.
