Folders in Houdini
   Views 781   Replies 8   Subscribers 0
Hi! My name is Kris Levin and I just got Indie version of Houdini. I´ve tested many different tools over my time as a student, and even though I had Houdini for a short period of time, I truly love this exciting program that delivers what it promises and much more. I have a noob question. Is there a thing as a folder like collections in Blender? For example I´m modeling a bust, and I Want to seperate different geometry parts into different folders nodes. This is for organization and better handling of files. Thank you for this great community and please, let me know if you know the answer.
Kris
I think what you are searching for is called subnetworks in Houdini.
For modeling, I would use different geo nodes for your various parts
as they are better to handle.
Cheers
CYTE
CYTE
Cheers
CYTE
I will check on that. Yes, I´ve heard something about them. Maybe that is it.
Ah geo nodes. Of course. Yeah, that sounds like a good solution. I will implement that. I sincerely thank you for your tip.
I have stumbled upon a problem. I have a model fbx that I imported, and as you said I want to copy some objects into different geo nodes. BUT, when I cut the geo and put it in a separate geo container, the geometry pastes in the origin and not where it originally was positioned. I do not know how to get around that?
Set it to this:
Screenshot 2025-03-16 130808.jpg (17.2 KB)
Thank you for the image. Now that I´m looking at it, the parameters, I have to somehow find that node. I do not know yet, which order to copy and paste, together with this option. BTW is that a node? Anyways, I will find a way.
Edited by krislevin - 2025年3月17日 02:34:28
I thought you used an object merge to organize your parts. If you change the order of OBJ nodes make sure "keep position when parenting" is checked on, under the transform tab.
Cheers
CYTE
CYTE
Cheers
CYTE
No no, but merge perhaps is a good idea. Ok, will do. Thanks a lot. I will test it and let you know. I´m very new to Houdini so talk to me like you would talk to a child
I think there are two levels of the geo tree. One is on the top. That is a single node. Then when you enter there, there is a node for every part. And that in itself contains the final geo. How would I merge it so I can copy and paste the parts in geo nodes. Top ones, of course. Thank you for your time.
