Hi!
I noticed that the usdViewportPurpose intrinsic attribute is an array of the USD purpose of an usd imported geometry using the SOP Modify LOP. The thing is that I think that maybe this should be an string attribute instead with the primitive purpose because right now the usdViewportPurpose intrinsic attribute is the same array for Proxy or Render geometries as you can see here:
On that example is very easy to see which prim has a Proxy purpose or the Render purpose because it is created with the Component Builder setup so the purposes are also on the primpath, but on a non-component builder prims, it can be more difficult to check which is the purpose from each one:
So, there is another method to select in SOP the purpose of the prims?
SOP Intrinsic: usdViewportPurpose
734 6 2- cdordelly
- 147 posts
- Heileif
- 136 posts
- pixelninja
- 33 posts
Heileif
Im only on my phone.
But if I remember correctly you only need create a string attribute named purpose with purpose you want as value.
That's definitely the case for sending geo from sops to lops. I think cdordelly is asking about a clear attribute to show what the purpose was when getting geo into sops from lops.
I had a quick look and I ran into the same thing, an intrinsic array is created that ends up being the same across all geo so you need to rely on the path to determine the purpose.
- Heileif
- 136 posts
The intrinsic attributes was indeed not useful.
But as a workaround this python code can work.
node = hou.pwd() geo = node.geometry() stage = hou.node("../../..").inputs()[0].stage() geo.addAttrib(hou.attribType.Prim, 'purpose', 'value') for prim in geo.prims(): path = prim.stringAttribValue('path') UsdPurpose = stage.GetObjectAtPath(path).GetAttribute('purpose').Get() prim.setAttribValue('purpose', UsdPurpose)
Edited by Heileif - April 29, 2024 05:05:04
- cdordelly
- 147 posts
Hi guys!
Thanks a lot for your answers, thanks so much for the code Heileif, I'll try to test it out today.
Definitely I was referring to get the USD Purpose in SOPs, I also recorded a video making a better demonstration of this but looks like the Heileif code will be the best solution for now.
I'll submit an RFE's to see if something can be improved on this.
- cdordelly
- 147 posts
- cdordelly
- 147 posts
Support kindly explained that the intrinsic usdViewportPurpose is not the primitive purpose, is the viewport purpose selected on the SOP Modify LOP, but there is still an easy workaround:
So, use the usdpurpose() function works perfectly fine to get the prim purpose, and also the kind:
Also inspired me to create an HDA to manage USD attributes in SOPs (to create them and extract them):
I hope I'll be able to share it with other tools any time soon.
Cheers!
Cheers!
