Calculating a matrix to move it back to the origin...
   2200   4   0
I calculated a matrix, but the inverting the matrix moves it to the origin by the rotation is messed up..
would so appreciate if someone took a look at what i am doing wrong ...
cheers
calcmatrix_question.hipnc (352.3 KB)
You should normalize your Y vector:
vector Y = normalize ( cross(X,tmp) );
You can also construct your matrix using maketransform function:
maketransform ( Z, Y, center );
For the center, you can also use the primitive's center:
primuv ( 0, "P", @primnum, 0.5 );
Other than these, the result looks correct.
hey @animatrix . thanks for the reply.. i did take your suggestions.. but when i apply the inverse matrix.. the pighead's orientation is off from the default. i was hoping to restore the default orientation.
thanks again. cheers
Your Rotation is prolly off because the rotation data stored is taken from the prim and not the object itself.
You can simply extract the orientation from the object and feed it back to the final output using attribute reorient .
Also if you just need to bring your animation to grid and then send it back to the world space,you can simply store the matrix and recall it later.
Look at the attached file.
Edited by MarXindia - April 18, 2022 16:06:21
calcmatrix_question_Fix.hipnc (371.7 KB)
It's not very clear what you are trying to do. The rotation you are seeing is normal because you are using a specific primitive to base the transform on like MarXindia mentioned. The geometry as is doesn't have any transformation.
If you just want to center the geometry using a specific primitive, you can either ignore the rotation in the computed matrix or just use the center of the primitive to move the geometry to the origin. You can also use the center of the geometry itself to do the same.
