HARS keeps crashing on Ubuntu 22.04
   5010   2   3
I'm trying to run houdini engine 18.5 in a python commandlet with Unreal 4.27 UE4Editor-Cmd; however, the following code throws does not work:
    houdini_engine = unreal.HoudiniPublicAPIBlueprintLib.get_api()
    if not houdini_engine:
        unreal.log_error('Houdini engine not found!')
    if not houdini_engine.is_session_valid():
        unreal.log_warning('Restarting houdini session')
        houdini_engine.restart_session()
LogPython: Warning: Restarting houdini session
Thrift: Wed Aug 3 21:41:07 2022 TSocket::open() connect() <Path: : Connection refused
A previous thread (related to C#) suggested calling HARS directly, but that crashes with invalid pointer:
/opt/hfs18.5/HARS -n hapi -a
free(): invalid pointer
2896:  (sent by pid 2896)
-- TRACEBACK BEGIN --
Traceback from HARS 18.5.759 (Compiled on linux-x86_64-gcc6.3):
stackTrace() <libHoudiniUT.so>
signalCallback(UTsignalHandlerArg) <libHoudiniUT.so>
UT_Signal::UT_ComboSignalHandler::operator()(int, siginfo_t*, void*) const <libHoudiniUT.so>
UT_Signal::processSignal(int, siginfo_t*, void*) <libHoudiniUT.so>
__sigaction <libc.so.6>
pthread_kill <libc.so.6>
raise <libc.so.6>
abort <libc.so.6>
__fsetlocking <libc.so.6>
timer_settime <libc.so.6>
__default_morecore <libc.so.6>
free <libc.so.6>
pxrInternal_v0_20__pxrReserved__::_DemangleNewRaw(std::string*) <libpxr_arch.so>
pxrInternal_v0_20__pxrReserved__::ArchDemangle(std::string*) <libpxr_arch.so>
pxrInternal_v0_20__pxrReserved__::ArchGetDemangled(char const*) <libpxr_arch.so>
pxrInternal_v0_20__pxrReserved__::Arch_ValidateAssumptions() <libpxr_arch.so>
pxrInternal_v0_20__pxrReserved__::(anonymous namespace)::Arch_InitConfig() <libpxr_arch.so>
__nptl_change_stack_perm <ld-linux-x86-64.so.2>
_dl_catch_exception <libc.so.6>
_dl_rtld_di_serinfo <ld-linux-x86-64.so.2>
_dl_find_dso_for_object <ld-linux-x86-64.so.2>
dlmopen <libc.so.6>
_dl_catch_error <libc.so.6>
dlerror <libc.so.6>
dlopen <libc.so.6>
hapilOpenHAPIDSO(char const*, int) <libHoudiniHAPIL.so>
hapilLoadDSOAndFindSymbols(int, char const*) <libHoudiniHAPIL.so>
HAPI_CreateInProcessSession <libHoudiniHAPIL.so>
(anonymous namespace)::hardCreateProcessor() <libHoudiniHARD.so>
HARD_Server::init(HARD_Server::ThriftServerType, HART_TransportType, std::shared_ptr<apache::thrift::transport::TServerTransport>) <libHoudiniHARD.so>
HARD_Server::HARD_Server(HARD_Server::ThriftServerType, HART_TransportType, bool, std::unique_ptr<HARD_Server::ReadyHandler, std::default_delete<HARD_Server::ReadyHandler> >, char const*, bool) <libHoudiniHARD.so>
_init <HARS>
__libc_init_first <libc.so.6>
__libc_start_main <libc.so.6>
_init <HARS>
-- TRACEBACK END --
This happens when running as normal user or as sudo. How do I fix this? I do have a valid houdini core license; i.e. sesictrl print-license shows an active license.
Update: I solved this by running HARS with a LD_PRELOAD; in second terminal; i.e.
LD_PRELOAD="/lib/x86_64-linux-gnu/libc_malloc_debug.so.0" ./HARS -s 9090
IIRC, this was not required on Ubuntu 20.04 or running Houding 19.5 on Ubuntu 22.04
Edited by mbroecker - Aug. 5, 2022 17:13:21
mbroecker
Yeah this was an issue with glibc 2.34 or later, which newer Ubuntu versions have. There was a fix in the 19.0 daily builds, but 18.5 and earlier does not have this fix
