Network view: Space between the Grid Line or Grid Points
   2287   2   0
Hi everyone,
Inside the network view, I really like using the grid line or points in the background to organize my node. The only things that bug me is that when I used “shift + A” to realign some of my node, the automatic spacing is a tiny bit bigger than the grid line depending on the node shape. If you looked at my image reference, the basic rectangle node do a correct spacing but the wrangler shape or a null shape is very different.
Is there a way to fix this in the preferences?
Thanks a lot
-Julien
D over network editor -> General tab -> Grid Spacing
It will not work with changing the grid spacing because the auto-align (“shift + A”) is relative to the node shape.
But It still better with the grid spacing higher on Y. Thanks
