I am primarily a concept artist and illustrator with an interest in procedural forms and a specialization in architectural/psychedelic design. Here are some examples of the stuff I make in Max, with the hopes that I can turboboost the creation of similar stuff in Houdini.
I am interested in creating forms like this in Houdini:
Also, creating swarms (3D scattering) for my images. (I already have 2D scattering covered via MultiScatter in Max.)
I am not very interested in motion graphics right now compared to making static forms/scenes for illustration, game levels, and some 3D printing on the side. My main software platform is currently 3DS Max/V-Ray, which I plan to continue using to compose most final static scenes. So the plan would be to use Houdini to create assets to bring into it (as well as UE4 down the line). I have not invested serious time into learning bottom-up procedural generation within Max (like MCG/scripting) because it seems like a potential dead end. Whereas Houdini seems like the type of software that I would never want to move from once I've learned it. As in, a better long-term investment.
Other creators have recommended Houdini to me because of the “way I think” and because of how flexible it is compared to Max for generating the kind of architectural/biomorphic/mathematical forms I love. But then I consider the opportunity cost of the learning time. While I have experience with node-based work (mainly procedural V-ray materials), I have no background in vector math, dot matrices, etc… and I have only scratched the surface on scripting (Maxscript). I am just not sure if learning all that would be overkill if I can just get 95% of the way there by further developing the hardsurface modeling/digital painting I already know how to do, even if takes longer per asset. But I'm bumping against some limits with the way I'm doing things now, specifically the ability to iterate on a type of form for complex scenes like cities.
I am also considering Grasshopper within Rhino as an alternative to Houdini, although I am not very experienced with Rhino and it is not intended for a game/illustration pipeline. But if Grasshopper is designed for generating static forms, and if it takes significantly less time to get up and running in for that, maybe I should bypass Houdini for now?
If I'm not interested in making things move, would it still take ~3 months to get to a point where I can make anything “useful”?
I'm still on the front end of my career with decades ahead of me so I'm thinking some investment might pay off over the years, but am still not sure if the mental effort would be better spent elsewhere for similar/better results. I would be giving up significant income/opportunity/creative energy to focus on this and I want to make sure it is worth the tradeoff.
I would love to hear Houdini users' thoughts on this. Especially if there are any recommended learning tracks for someone with my goals. Thanks!
Would Houdini be overkill for me? (Static form creation)
11492 18 1- Zirnworks
- animatrix_
- 4677 posts
No, this is perfect for Houdini, go for it
Btw really cool artwork
Edited by animatrix_ - 2019年3月11日 12:46:09
- Midphase
- 833 posts
I'll be a bit less enthusiastic than Animatrix and go with “it depends”
You state: “I have no background in vector math, dot matrices, etc… and I have only scratched the surface on scripting (Maxscript). I am just not sure if learning all that would be overkill if I can just get 95% of the way there by further developing the hardsurface modeling/digital painting I already know how to do, even if takes longer per asset.”
That gives me a bit of pause in eagerly recommending that you jump over to Houdini. The first question to you would relate to the if-it-ain't-broken saying. Are you finding limitations in MAX that you can't overcome? Is it negatively impacting your work?
You seem like a pretty smart guy, but in 3 months you're still likely going to be grappling with the basics and trying to wrap your head around WTF a Quaternion is.
When I jumped over to Houdini from C4D, it was because I was hitting walls with C4D and I needed to work with an application which could handle volumes, fluids and physics more robustly (and without thousands of $ add-ons). So for me it was a pretty cut and dry decision. For you, it depends! ;-)
>>Kays
- Konstantin Magnus
- 682 posts
From what I can see in your images, you will love Houdini.
- amm
- 98 posts
ZirnworksAccording to Grasshopper nodes [rhino.github.io], actually I'm not sure is it GH *itself* a shortest path compared to Houdini. Even basic GH set, without all these addons, is looking like a vector math wonderland, compared to comprehensive, but still generic ‘DCC style’ set in H.
However, there are another parameters, like general background. Imho Houdini is more about ‘beauty of code’, where resulting model or render is a kind of representation of ‘node art’ or ‘code art’ - plus of course simulations, solvers and such. So that's reason for optimistic ideas, how Houdini is ‘ideal’ for everything procedural, actually people just don't care that much.
Rhino and Grasshopper are coming from very CAD environment, so I'd be pretty sure you'll be able to find much more of practical tutorials for your goals, how to create this or that, possibly skipping the technical parts, at least when you're close to CAD world. Perhaps not so flexible, but don't forget that flexibility in Houdini is not granted, it's your job to enable it. It's not going without price of long times to evaluate, where any small inconsistency somewhere in graph of hundred nodes, could create unwanted result.
While ago I was experimenting with similar [forums.odforce.net], space ships and suits stuff. Today I'd probably choose a mix of any classic modeling 3d app, Blender or else, and CAD nurbs app (Rhino and Grashopper, MoI and Elephant, F360, whatever). Partially because CAD NurbS engines are far stronger than in any DCC (and Houdini nurbs is not best one, nicely to say, even in DCC). Mainly, because they are just up to task.
When it comes to learning the vectors and such, I'd go with Houdini, definitively. Also, H is unmatched in creating a beautiful networks
Edited by amm - 2019年3月11日 19:46:29
- anon_user_37409885
- 4189 posts
- Kai Xu
- 21 posts
http://www.entagma.com/ [www.entagma.com]
Check their websites and see if Houdini could be helpful for you
- harryabreu
- 76 posts
Hi Zirnworks welcome to Houdini's world.
To make your way easy you can try this way to learn:
01 - Introduction to Houdini 15
by John Moncrief - Pluralsight
02 - HOUDINI FOUNDATIONS BOOK (https://www.sidefx.com/tutorials/houdini-foundations-book/)
03 - Introduction to Houdini https://www.sidefx.com/learn/collections/introduction-to-houdini/ [www.sidefx.com]
04 - https://www.cgcircuit.com/tutorial/houdini-for-the-new-artist [www.cgcircuit.com]
After this you will have a good understand How to start you path in Houdini.
To be honest all images that you showed can be done in Houdini with no problem but first you need put some effort in learn the software all your time will be re-compensate.
Have a good time and any question you are welcome to our forum.
- Hezza
- 17 posts
It'll be a big investment in time to get back to producing work to the level you are currently in Max but once you're there you won't be limited by plugins (or autodesk). As you grow as an artist you'll have room to expand into Houdini.
I've been using Houdini for nearly 3 years now and I'd say it took me a year to really ‘get’ it, and then every few months I have another big revelation about how everything is connected and how data is moved around. This is after using Maya for 14 years, I now dread having to load it up.
You can get a long way without learning vector math but it will definitely help down the road. As someone else said about, check out http://www.entagma.com/ [www.entagma.com] for some cool procedural tutorials, though they're definitely on the technical end of things.
The tutorials section of sidefx is great too.
https://www.sidefx.com/tutorials/ [www.sidefx.com]
- filipw
- 137 posts
Just chiming in as a H beginner (one year exp): seems your artstyle is perfact fit for what can be done on Houdini. But as everybody mentions above: It will take time and many experiments and courses until it will be useful. I have a background as a graphics programmer (C++, opengl, glsl) and still think it is very cumbersome (but also fantastic!). The reason is the decades of sediment, the mixes of scripting languages, the old tutorials often being totally out of date etc. I view it as an IDE for graphics and not at all simular to a regular DCC.
But if you got time: Go for it! it is a fun process!
- AAlhosaini
Hi Zirnworks,
I found this post lately. You have a great piece of art.
your situation is typical of mine.. still thinking where to go in this field. Now It's been 2 years from the date you post this, please tell me your experience if you joined Houdini club, did you find what you were asking for ?
I wish you still able to reply my question here.
best of luck,
best of luck,
- vusta
- 555 posts
if you most likely just want to create static geos..well then just get Apprentice and take it for a spin...absolutely nothing to lose except your time...but you HAVE to pay that way.
I've done enough MCGs to know that Houdini is far more flexible
doing stuff like this with MCG will not leave you with much hair left...
speaking about FREE...Blender 2.93 are going nodal too...I can see already it's way better than MCG but not at Houdini's maturity yet (obviously) why not take Blender out for a spin too ?
- Berk_Erdag
- 86 posts
- AAlhosaini
vusta
I respect MCG surely, but still no much learning recourses available. Houdini is the master of the proceduralism, with the ability to combine your geo with a robust fluid dynamics effects, fractals, L-trees, Vex..etc, which are missing in the other 3d platforms like Max.
I really envoy Blender community for the continues developing they get, but still going to blender means you should re-learn many aspects you have already mastered in Max for instance, and you need time to get used to it, and to practice it.
- vusta
- 555 posts
AAlhosainidon't invest time/effort in it, because Autodesk has stopped MCG dev since version 2018, so they've made the decision for you...no morevusta
other nodal max plugins are popping up so maybe nodes in max is not quite dead, just maybe MCG took the wrong path.
- Island
- 340 posts
Houdini would be great for that. Grasshopper/rhino is a good semi procedural CAD system (but surprisingly lacks even the procedural features of solidworks or fusion for anything mechanical) and does not have any advanced rendering. Unless you plan to actually build something, I would avoid a CAD workflow.
Michael Gibson, one of the creators of Rhino, who now develops moi3d, said this in February: "basically with the "fill in patch by patch" strategy it's a dying art form even in programs with multi-sided G2 continuity blending because it's so sensitive. Just having G2 continuity by itself doesn't do enough, even if a surface is G2 to another right at an edge, if the surface curvature changes too much in a localized area around the boundary it will leave some visible evidence of the patch topology in the model."
He recommended polygon modeling, such as done in Houdini and many other programs for organic shapes.
Edited by Island - 2021年3月15日 16:13:40
- Terence Ziegler
- 64 posts
Zirnworks,
never underestimate the power a fresh tool, a fresh approach, can bring to your work.
Houdini, for me at least, unlocks whole different parts of my creative mind. It doesn't work like any other software. It can be frustrating, but also very, very invigorating to use. Borderline magical when you have those "ahhhaaaaaa!" moments.
Give it a try.
T
Give it a try.
T
- JonyWest
I think that Houdini is absolutely the way to go but I'm also at the point where you are. I've been having trouble finding good resources for organic/procedural modeling that doesn't look really bland. by the way, which Procreate Alternatives For Windows 10 would you recommend to me? I found a couple of free and paid options on techshout.com [www.techshout.com] but I don't know which one to choose yet. I would be very grateful if you share your experience and suggestions. I hope for your help and thank you in advance!
Edited by JonyWest - 2021年3月29日 07:26:53
- 0tt0manl3g3nd
- 9 posts
With houdini it can be totally Different ,..U can have More perfect Realism ...
I think ur looking for Environment and Technicle designs so these are artist u need to go thru ..These will be ur best way
Saul espinosa Patreon -( For environment,Procedural Texturing of environment with
quixel and cops and shading of materials,Scattering,Procedural
rocks and SPEEDtree trees)
Timucin ozger Elite fallen tutorial-(Procedural cities with Python)
Andrian Lambert on houdini tutorials
You might need to Learn pragnant vex as mentioned above for procedural modelling and the shapes ur looking for..
