I have two basic questions regarding the node editor:
1. is the default spacing of nodes configurable? For example when you align nodes, where is that spacing defined vertically / horizontally?
2. is there an option to delay the middle mouse node info window? When navigating big networks with middle mouse butotn I get crashes if instead of panning it tries to display the node info window
Node Editor Setting / Behaviour
747 4 1- coccarolla
- 71 posts
- l_s_galante
- 12 posts
coccarolla
Press 'D' in the network editor to bring up display options. Or in the network editor menu go to View > Display Options. On the first tab there should be a grid spacing option. I am not sure if this is what you are looking for.
coccarolla
The best I can think of is 'extending the network editor' [www.sidefx.com] in the documentation. I don't think I have ever done anything with mouse handling, so I don't know if it is possible to override the default behavior. Of course, you would have to understand some python in order to do this.
- animatrix_
- 4672 posts
coccarolla
For #2, I submitted an RFE about this, to not show the MMB info dialog if the user is panning the view, it's easy to accidentally MMB on a node with rapid panning. I am not sure if it's implemented yet.
- coccarolla
- 71 posts
- l_s_galante
- 12 posts
I looked in the python api and there is indeed a way to do this, but still some scripting required. It can be installed by looking at the documentation page I mentioned earlier.
If you want to actually move the nodes onto the grid after spacing them you could write some more code, or just select all the nodes and drag them to the grid with the cursor. The default grid size is 2x1, and can be changed by doing what I mentioned in my previous response. You will of course need to disable the default layout hotkey.
import hou from canvaseventtypes import * import nodegraphdisplay as display import nodegraphview as view def action(uievent): if isinstance(uievent, KeyboardEvent) and uievent.eventtype == 'keyhit': editor = uievent.editor node = editor.currentNode() parent = node.parent() key = uievent.key step_x = 2 step_y = 1 if key == "A": parent.layoutChildren(horizontal_spacing=step_x, vertical_spacing=step_y)
Edited by l_s_galante - 2024年10月11日 08:57:47
