I'm trying to group primitives with length more than specified value. For that i used Attribute Wrangle with this VEXpression:
`f@group_t = length({@XMAX-@XMIN,@YMAX-@YMIN,@ZMAX-@ZMIN})<0.5;`
But i'm getting this error message
Warning: Errors or warnings encountered during VEX compile:
/obj/subnet1/frames/attribwrangle1/attribvop1/snippet1: Syntax error, unexpected identifier. (1,28)..
But at this position(1,28) is only middle of the @XMIN attribute and nothing else. And i can't get what's wrong with this.
VEX Syntax issues
3839 4 1-
- kamanji
- neil_math_comp
- 1743 posts
The syntax error is because the
However, that will probably only give the results you're looking for if you have those 6 attributes on your input geometry. If you're looking for the size of the diagonal of the bounding box of a primitive, you can try:
Hopefully that helps.
{0,0,0}
syntax only works for numeric literal values. You can use the set(0,0,0)
syntax instead.However, that will probably only give the results you're looking for if you have those 6 attributes on your input geometry. If you're looking for the size of the diagonal of the bounding box of a primitive, you can try:
f@group_t = length(getbbox_size(0,itoa(@primnum)))<0.5;
- kamanji
- maya4fun
-I all I have a problem qith this formula on attrib wrangler:
int pcloud = pcopen(0, "P", @P, 2.1, 10);
if (pcnumfound(pcloud) < 5);
removepoint(0, @ptnum);
-the report error is :
Invalid source /obj/origin_box/attribwrangle1/attribvop1.
(Error: Syntax error, unexpected '(', expecting identifier or '['. (5,16)).
any help will be apprecited. Thank you.
Emmanuel
Emmanuel
- animatrix_
- 4832 posts
You have to remove ; after pcnumfound:
int pcloud = pcopen(0, "P", @P, 2.1, 10); if (pcnumfound(pcloud) < 5) { removepoint(0, @ptnum); }
