VEX: Get Min/Max Values of a Texture (the Fastest Way?)
   Views 451   Replies 4   Subscribers 0
Hi!
I need to find the min and max value of a displacement texture. I was using a Detail Wrangle to go over each pixel but its a bit slow with 4K textures. Is there a trick to getting the min/max values faster (with less calculations)?
-Olivier
The fastest method is likely to load the texture into COPs and use the Volume Reduce SOP. You have to split the volume into scalar volumes using the Volume Vector Split SOP as Volume Reduce SOP doesn't support collated volumes.
you can also use Statistics COP or Prefix Sum COP
Edited by tamte - 2025年4月21日 17:28:18
Oh, I was avoiding 20.5 because of the slow startup + crashes. I guess I wont have a choice.
Thanks for the infos!
-Olivier
olivierth
You dont need 20.5 for Volume Reduce SOP
