Hello.
How can i use “pscale” parameter with “mantra delayed load” geometry shader ?
I have a lot of points, but all points looks too big - how can i set “pscale” point attribute, on Delayed Load shader ? It possible ?
delayed load and PSCALE
18815 28 2- live_fx
- 160 posts
- pclaes
- 257 posts
You can delayed load instance. And instances can make use of your attributes.
There is a file at the bottom of this blog post that contains a setup for delayed load instancing:
http://www.peterclaes.be/blog/?p=34 [peterclaes.be]
- live_fx
- 160 posts
pclaes
a lot of thanks, pclaes
- mzigaib
- 978 posts
- mzigaib
- 978 posts
- koen
- 793 posts
i don't think you can do that out of the box. we wrote our own to be able to adjust scale (and v). if you have worked with the hdk before this is quit simple, based on this example:
http://www.sidefx.com/docs/hdk11.1/_v_r_a_y_2_v_r_a_y___demo_file_8_c-example.html [sidefx.com]
also, it is worth sending an rfe to sidefx about adding a cvex context to the delayed load, that would allow you to run some vex code when de file gets loaded by mantra allowing for this and many other things.
koen
koen
- mzigaib
- 978 posts
- bareya
- 31 posts
Hey guys I did something like this:
http://bareya.net/index.php/2011/10/27/delayed-load-procedural-cvex-shader/ [bareya.net]
maybe it will be helpful for you
Piotr
Piotr
- mzigaib
- 978 posts
- mzigaib
- 978 posts
- bareya
- 31 posts
Hey I moved project to:
http://code.google.com/p/delayed-load-procedural-cvex/ [code.google.com]
There you will find compiled so file.
Cheers
Cheers
- mzigaib
- 978 posts
- bareya
- 31 posts
- mzigaib
- 978 posts
Thank you very much for the help again.
Now I don't get more the error but I got black renders and nothing on alpha, still using your scene example file.
In the example file the “geo” node is using a vopsurface1 that's not existent on the shopnet so I am using a constant instead just to see if I can get something, even so nothing.
Correcting:
Even saving the files on the corrected places I am still getting the error.
I have both 11.1 and 11.0 installed could be this the problem even both of them having the files in the correct places?
Correcting:
- bareya
- 31 posts
Hey,
Hmm that is strange, did you try to recompile source code ?
svn checkout http://delayed-load-procedural-cvex.googlecode.com/svn/ [delayed-load-procedural-cvex.googlecode.com] delayed-load-procedural-cvex-read-only
cd delayed-load-procedural-cvex-read-only/trunk/source
make
I fixed problem with bounding box.
EDIT:
It's my fault!
Geometry is not included to example, so you have to go geo1 and bake geometry using ROP! Because Delayed Load can't find bgeo file.
I am sorry, I have to fix it!
EDIT2:
fixed!
Cheers!
make
EDIT:
It's my fault!
EDIT2:
fixed!
Cheers!
- mzigaib
- 978 posts
- bareya
- 31 posts
no worries!
first you have to download latest version:
then go to dir:
and compile!
make
let me know how's going
cheers!
then go to dir:
and compile!
make
cheers!
- moondeer
- 14 posts
What I did was to take one one of the delayed load sequences, drop in a pointsop and dial in a good pscale.
That single was about 3 mil points, so hou handled it just fine.
Then I added that same pointsop to each and used a georop to write out
Only a few frames of all 5 delayed load sequences again. More render tests and scale tweaks followed… Finally I wrote out all the frames of all the seq.
I believe I also added a color attribute as well.
Kinda the long way around, but it worked.
- mzigaib
- 978 posts
bareya
no worries!
then go to dir:
and compile!
make
cheers!
Thanks for the help, sorry the delay.
But I am a little confused I guess I forgot to mention that I have no experience in programing, shame on me. ops:
All this code and directories should I do it on phyton shell, houdini shell or any other shell?
Thanks.
- bareya
- 31 posts
