I use a hotkey for turning on the Grid in the network editor but it cycles between None, Lines and Points. I personally only use the Lines when I display the grid. But the cycling forces me to press it twice when I want to turn off the Grid display.
There should be one toggle for Lines, and one for Points. So whenever you use press one, it would display it if it's not already visible. If it's visible, then it would turn it off, i.e. set it to None.
Snapping hotkey is fine, it's just the grid/points display that's combined into a single hotkey as a cycle, instead of separate toggles.
USABILITY: Separate hotkeys for network editor grid display
1590 0 0- animatrix_
- 4733 posts
