Sorting issue..
   1193   4   2
Hello
I created lines from the bottom edges of the boxes, but there is an issue with point sort. Is there a way to rotate the lines clockwise for each box?
sorttest.hiplc (1.3 MB)
Hello - Not quite sure if this is what you mean but if you drop down a 'Polypath' then a 'Sort' and sort by vertex order, each of the connected prims will then have pt counts that are sequential along the path.
Love Houdini
Hatchery
I want the orientation of @N to remain consistent and connect in one direction. Since I'm fetching boxes in Unreal, I can't predict the initial point direction. Therefore, after fetching, the points should be sorted clockwise for each box.
You can create an angle attribute in VEX (Point Wrangle) and then sort the points using this attribute:
@angle = degrees ( atan2 ( @P.z, @P.x ) );
The Labs Sort SOP has a Circular sorting option built into it.
