multiple uv sets from maya to houdini
1931 4 1- shadyellaithy
- 3 posts
hello all , i have a model with 2 uv sets , one for fur and other for texture , when i export to Houdini , it only read the texture uv m how can i make it jump between the 2 uv sets ? is there a attribute wrangler , when i export from maya i tick on the write uv wets and write uv , am i missing something in exporting from maya ?
thanks all
thanks all
- GlenD
- 118 posts
- shadyellaithy
- 3 posts
- tamte
- 8622 posts
that menu shows only 2 types of attributes
- attributes named uv, uv1, uv2, ...
- attributes with arbitrary name marked as "Texture Coordinate"
so first thing to do is to have a look what attributes your geo has (MMB on the node)
you may see something like this
if you see your custom uv attribute, in this example it's a vertex attribute myCustomUV then all you need to do is make sure it's marked as "Texture Coord" which will appear as (Tex) next to the name like uv attrib has in screenshot
to do that you can either do Attrib Create SOP (match the name, type, size, set to Texture Coordinate) and uncheck Write Values
(in case your attribute is point attribute instead of vertex, or if the size is float 2 instead 3, then adjust accordingly):
or alternatively you can do Attrib Wrangle in Detail mode:
and then you should see (Tex) next to your attribute and also it should appear in the UV view:
setattribtypeinfo(0, "vertex", "myCustomUV", "texturecoord");
Edited by tamte - July 31, 2023 05:38:14
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- shadyellaithy
- 3 posts
helloo tamte
thanks for the replay , the issue is that i cannot find from my imported file the secound uv set on my geo , so i guess something missing while i export my maya file , i dont know what is the step , it always read my first uv set not the secound one , and i am sure i checked the uvset option in the maya export for the usd file
