HDA node coloring
   3768   2   2
how to set the default resistant color (i.e. blue) of a HDA node? ANd no, I dont want ot colorize it via the colorchooser to change it after creation. Dont find anything in the type properties of the hda..
thanks in advance
Edited by Follyx - March 16, 2022 11:01:13
Follyx
You can use OnCreated script section either directly in HDA [www.sidefx.com]
Or externally here [www.sidefx.com]
FX Supervisor
Method Studios, NY
If you don't want the color to be embedded into the HDA, you can also CTRL drag a color onto a node instace of your HDA. SRC [www.sidefx.com] DOCS [www.sidefx.com]
Manuel Köster - Senior Technical Artist @Remedy Entertainment
https://www.remedygames.com/ [www.remedygames.com]
http://shadesoforange.de/ [shadesoforange.de]
https://twitter.com/ShadesOfOrange_ [twitter.com]
