C++ Wrangle: The Last Frontier In Custom Tool Development From Within Houdini
   16305   28   3
The most powerful wrangle operator due to the sheer fire power of the HDK. Performance increase can vary from a few times to thousands of times depending on the scenario.
Edited by animatrix_ - 2016年9月8日 11:46:54
Cool!
-b
http://www.racecar.no [www.racecar.no]
No assembler wrangle? Lame.
I'm also disappointed with the lack of assembler
Is it a wrapper of Python SOP With inlineccp or something else?
Assembler is overrated
symek
It's a wrapper around inlinecpp.
I hope SESI adds this operator to H16, possibly ship it with the required libraries.
Edited by animatrix_ - 2016年6月20日 12:29:22
Does have this Cpp Wrangle and OpenCl Wrangle a RFE ID? Would you mind share it there?
Yes OpenCL Wrangle RFE ID #75612, C++ Wrangle RFE ID #76080.
Please submit these to SESI so they would be added to H16. A lot of people contacted me about these operators and said that they are interested to learn these languages after seeing the performance gains in my videos.
I think tools like this and your OpenCL Wrangle SOP that harness and empower Houdini dramatically for TD works, do not need so much community requests for being addressed. SESI should be enough wise for addressing these as Houdini new features, which they are
and congratulations @pusat.
you have done some great jobs.
Thanks sorian, these tools would definitely make Houdini more future proof in my opinion, thanks to the incredible talent in our community, to inspire and innovate beyond what Houdini is capable of.
I hope people RFE these, as a few people won't make much of a bang to convince SESI to consider implementing these.
Can you share it there?
wangguo
Where? I will release it soon. I released OpenCL Wrangle SOP yesterday.
You can download the operator here:
C++ Wrangle [dropbox.com]
I added Clip Geometry code in the video as a preset so you can experiment with it.
thanks, pusat
Therefore with this Wrangle can we create our own plugin in Houdini without using of Visual Studio for example?
Is this like Python API in Maya and using that in its script editor?
And finally can we access to all Houdini's API data?
best regards.
You should be able to do so. There are some limitations in inlinecpp i.e. you can't change pixel colors of a COP directly without creating an array of all pixel values, modify these, and then set them back. For geometry, you are directly modifying it though so no overhead AFAIK.
It's not like Maya's Python API, which is a wrapper. You can access all of HDK.
mestela
Lol
https://www.imdb.com/name/nm8408875/ [www.imdb.com]
pusat
I thought inlinecpp requires you to have a working dev setup for the HDK. So on windows you would need to have Visual Studio set up properly before you can use it.
blackpixel
pusat
Yo do. I thought he meant developing C++ tools without actually using the VS IDE, not avoid installing it.
I think I may have RFE'd this one too. It would indeed be useful. Great work with this!
-G
Thanks, the more RFEs the better chances SESI will give this kind of powerful SOPs to TDs.
