Plastic wrap- UPDATE - $500
6705 27 1- MrCedric
- 56 posts
Hello
I'm a blender user and even it's procedural, Houdini is too difficuly for me.
I need a very friendly asset to make plastic wrap on different objects.
The slots I need :
- the model that is going to be vacuum-packed
- pressure slider (to select the vacuum I want)
- cloth spec sliders (to go from a very silky fabric to a totally rigid and breakable ones like foil)
- gravity slider
- a way to export the mesh in high-res obj
So all this in one simple window.
This is a very clear brief, so if you are interested please send me your quote (I'm a freelance so please be gentle, I can not pay too much)
IMPORTANT INFO : I pay only if the result is what I'm looking for (by the past I had bad experience).
So it means that you show me some results, maybe 2 or 3 with different pressure and silky/foil cloth, and if it's ok I give you my GO then I pay you and you can produce the simple asset.
Feel free to DM me
Best regards
Cedric
The slots I need :
- gravity slider
Feel free to DM me
Best regards
Cedric
Edited by MrCedric - 2023年4月15日 14:09:12
- CYTE
- 703 posts
- CYTE
- 703 posts
- MrCedric
- 56 posts
- CYTE
- 703 posts
- MrCedric
- 56 posts
- CYTE
- 703 posts
Here is the fixed version:
Yes put it in your otls folder. The folder is in your Houdini Preference folder. If its not there create it and put the hda inside it.
Open Houdini.
then create a geo container in that container create a pighead or whatever. then search for the plastik shrink wrap node.
Open Houdini.
Edited by CYTE - 2023年3月29日 05:55:20
- MrCedric
- 56 posts
- CYTE
- 703 posts
- MrCedric
- 56 posts
- CYTE
- 703 posts
- MrCedric
- 56 posts
- CYTE
- 703 posts
- MrCedric
- 56 posts
- CYTE
- 703 posts
- MrCedric
- 56 posts
- MrCedric
- 56 posts
- CYTE
- 703 posts
Hey MrCedric,
I tried the cyte-PlasticShrinkWrap-1.1_blackbox.hda on a fresh Houdini install and it works. So I don't know what is causing the issue for you. Maybe someone else could try the hda and give some feedback. That would help in this case.
Also on your screenshot, it seams that there is still the 1.0 version somewhere in your setup...
Cheers
CYTE
Cheers
CYTE
Edited by CYTE - 2023年4月17日 02:30:49
- animatrix_
- 4621 posts
I just tried it and after copy pasting a node instance, I am getting missing HDA errors. I think the other HDAs used inside the plastic shrink wrap HDA are not included.
- CYTE
- 703 posts
Hey animatrix,
thanks for testing. It's strange I unlocked all used assets. It also worked for me on a fresh User folder, so none of the other assets were present. No idea. I made a new version and made sure all other assets were wiped.
edit: the savetodisk button does not work on the black-box version.(limitation of black-box) but it will work on the open version.
Cheers
CYTE
Cheers
CYTE
Edited by CYTE - 2023年4月17日 15:00:02
