Can I reinstall the SERVER key?
Sometimes the
SERVER
key may become invalid if you change the computer name or upgrade your hardware. Changing the computer name is not advisable unless all the licenses have been returned. Most common reason for invalidSERVER
key, then, is hardware upgrade that changes the server code (server id).To install a new valid
SERVER
key for your computer, please follow these steps:- Open the License Administrator (hkey)
- Select File -> Install Licenses
- Log in
- In the dialog box click on the "Licenses" tab
- Select the checkbox to reinstall the
SERVER
key - Press Install button
This should reinstall the new
SERVER
key for your computer.
