How do I Install licenses non-graphically?
If you are running a headless server or are having issues using the graphical License Administrator utility hkey, the non-graphical utility sesictrl will allow you to administer the license server through the command line.
To obtain help information about a specific command run: sesictrl
--help
If you need help information from the legacy sesictrl interface enter: sesictrl --legacy-helpExamples of using sesictrl:
- Redeem license entitlements: sesictrl redeem
- Install generated keystrings: sesictrl install copy-generated-keystring-here
- Return licenses: sesictrl return-license
- Generate the license diagnostics: sesictrl diagnostic
- License usage: sesictrl print-license
To access the program sesictrl, you will need to source the Houdini environment.
Windows
- Start->Search and type "Command Line Tools 18.0".
- Or, C:/Program Files/Side Effects Software/ Houdini 18.0.x/bin/hcmd.exe
- Type sesictrl at the prompt to see the available options.
OSX
- Spotlight search for Houdini Terminal for your specific Houdini version.
- Applications->Houdini->Current->Utilities->Houdini Terminal 18.0
- You can also source the Houdini environment in your shell:
- cd /Applications/Houdini/Houdini18.0.397/Frameworks/Houdini.framework/Versions/Current/Resources
- source ./houdini_setup
Linux
- The sesictrl program is located in /usr/lib/sesi
- Type ./sesictrl to see the available options
- cd /opt/hfs18.0
- source houdini_setup
For more information about sesictrl please refer to www.sidefx.com/docs/houdini/ref/utils/sesictrl.html
