How can I manually install licenses?
From the license server machine (or from a client that has write-access to the license server):
- Open the License Administrator (hkey)
- Select File -> Manually Enter Keys...
- Copy and Paste each keystring into a text box using Ctrl+V and press OK
Make sure you copy the entire keystring. Failing to do so will cause Houdini not to function.
Each keystring needs to be entered on a separate line in the License Administrator GUI.
A new keystring begins at the keyword:
SERVER
,LICENSE
,INCREMENT
,UPGRADE
orEXTEND
