How do I install Houdini on Linux?
The installer must be run using sudo.
Note:
- Make sure that the install file is not located in root's home folder (/root) as this will give you permission errors during the install process.
- Install the License Server component if:
- installing for Houdini Indie or Houdini Apprentice.
- the computer is a license server to serve licenses to client machines, or
- a Workstation (nodelock, not using a remote license server) is installed.
- If the computer is a client machine and will use a remote license server, you do not need to install the License Server component.
Download:
Download the latest Production or Daily build of Houdini.
To install:
- Open a Terminal.
- Unpack the downloaded tar.gz archive.
$ tar -xvf houdini-20.5.550-linux_x86_64_gcc11.2.tar.gz
// This should create a directory calledhoudini-20.5.550-linux_x86_64_gcc11.2
- Go into the unpacked directory and run the houdini.install script using sudo.
$ cd houdini-20.5.550-linux_x86_64_gcc11.2
$ sudo ./houdini.install
Alternatively, you can also double click on thehoudini.install
file with your mouse. It will run the installer in a terminal.
4. If installing for a license server, or Houdini Apprentice or Houdini Indie, make sure to install the License Server component (option 5 in the image above) in the installer.HOUDINI 20.5.550 INSTALLATION Enter a number to toggle an item to be installed. INSTALL 1. Houdini yes 2. Desktop Menus for Houdini yes 3. Symlinks in /usr/local/bin no 4. Symlink /opt/hfs/20.5 to install directory yes 5. License Server no 6. Avahi (Third-party) no 7. SideFx Labs no 8. Houdini Engine for Maya no 9. Houdini Engine for Unreal no 10. HQueue Server no 11. HQueue Client no D. Change installation directory (/opt/hfs/XX.X.XXX) F. Finished selections, proceed to next step Q. Quit (no installation will be attempted)
5. The licensing menu may appear during the installation process if no installed licenses can be detected.
* If you are installing Apprentice, choose "Install Houdini Apprentice license. * If you are installing a commercial product, choose I have a paid license for Houdini.For more information about licensing Houdini please refer to Licensing a Houdini product
To launch Houdini from the Terminal, type the following:
$ cd /opt/hfs20.5
$ source houdini_setup
// This should setup the Houdini environment for you.$ houdini
