How do I install Houdini on Mac OSX?
Run the Houdini setup program by double-clicking the downloaded .dmg file.
Note:
- Install the License Server component if:
- installing for Houdini Indie or Houdini Apprentice.
- the computer is a license server to serve licenses to client machines, or
- a Workstation (nodelock, not using a remote license server) is installed.
- If the computer is a client machine and will use a remote license server, you do not need to install the License Server component.
Once installed, the application is available by default through:
- Go → Applications → Houdini → Houdini 20.5.xxx → Houdini 20.5.xxx
You will be prompted to install your Houdini licenses when you launch the software the first time.
For more information about licensing Houdini please refer to Licensing a Houdini product
