Feature | Mantra | H19.5 Karma CPU | H19.5 Karma XPU |
Status | Production-ready | Production-ready | Beta |
CPU Renderer | Yes | Yes | Yes [Hybrid] |
GPU Renderer | No | No | Yes [Nvidia] |
USD/Solaris Support | No | Yes | Yes |
IFD Support | Yes | No | No |
Open Image IO | Yes | with Env Variable | Yes | Yes |
Standard Surface Shader | Principled - VEX | Principled - VEX/USD Preview/MaterialX | USD Preview/MaterialX |
VEX shading | Yes | Some trace() function support | No |
CVEX: Lens Shader | Yes | Yes | Karma Physical Lens |
CVEX: Volume Procedurals | Yes | Planned for Future Release | No |
Toon Shader | VEX Shading | VEX Shading | No |
Rounded edge/Dirt masks | Yes | Yes | No |
Texture Baking | Yes | Preliminary Support | No |
MaterialX Surface Shaders | No | Mtlx Standard Surface/USD Preview | Mtlx Standard Surface/USD Preview |
MaterialX Disney 2012/2015 | No | No | No |
Custom MaterialX PBR Shaders | No | Yes | Planned for Future Release |
MaterialX SSS | No | Yes | Yes |
MaterialX Color Management | No | Planned for Future Release | Planned for Future Release |
MaterialX Displacement | No | Yes | Yes |
Material Overrides | Material Stylesheets | [USD] | Assign Material and Material Variation LOPS | [USD] | Assign Material and Material Variation LOPS |
Adaptive Sampling | Yes | Yes | No |
Motion Blur | Yes | Yes | Yes |
Depth of Field | Yes | Yes | Yes |
Physical Sub Surface Scattering | Yes | Yes | No |
Random Walk Sub Surface Scattering | No | Yes | Yes |
Volumes | Yes | Yes | Yes [Pyro Preview Shader] |
Heightfields | Yes | Yes via Solaris | Yes via Solaris |
Instancing | Yes | Yes | Yes |
Nested Instancing | No | Yes | Yes [Fixed Number of Levels] |
Deferred Geometry Load | Yes | Planned for Future Release | Planned for Future Release |
Subdivision | HoudiniSubdiv/OpenSubdiv | OpenSubdiv | OpenSubdiv |
Displacement Shading | Yes | Yes | Yes |
Crowd Support | Yes | Partial Support | USDSkel support, but not optimized | Partial Support | USDSkel support, but not optimized |
NURBS | Yes | Tesselated at Fixed Rate | Tesselated at Fixed Rate |
Lens Shaders | Yes | Custom VEX lens shaders | Karma Physical Lens |
Absorption and Nested Dielectrics | Yes | Nested Dielectrics | No |
Pyro Shader for Volumes | Yes | Yes | SimplifiedLimited Version |
HdCoordSystem support for shaders | No | Yes | No |
Uniform Volume Geometry | Yes | Yes | No |
Denoising | Optix | Intel | Optix | Intel | Optix | Intel |
AOVs | Yes | Yes | Yes [no LPE]) |
Deep Images | Yes | Yes | No |
Cryptomatte | Yes | Yes | No |
Light type: Point | Point Light | Yes | Yes |
Light type: Dome | Environment Light | Yes | Yes |
Portals on Dome Light | Portal Light | Yes | Planned for Future Release |
Light type: Distant | Distant Light | Yes | Yes |
Light type: Disk | Area Light | Yes | Yes |
Light type: Rectangle | Area Light | Yes | Yes |
Light type: Sphere | Area Light | Yes | Yes |
Light type: Cylinder | Area Light | Yes | Yes |
Light type: Geometry | Geometry/Volume Light | Yes (points, curves, meshes, volumes) | Planned for Future Release |
Light type: Portal | Yes | Yes | No |
Shaping Control: Cone | Spot light | Yes | Yes |
Shaping Control: Focus | Yes | Yes | Yes |
Shaping Control: Barn Doors | Yes | Yes | Yes |
Shaping Control: IES Mapping | Yes | Yes | Planned for Future Release |
Light Filters | No | Yes | Yes [Fixed Set] |
Light Linking | Yes | Yes [No Geometry Lights] | Yes [No Geometry Lights] |
Geometry Lights | Yes | Yes [points, curves, meshes, volumes] | No |
Hair & Fur | Yes | Yes | Yes |
Render Curves | Yes | Yes [tubes, ribbons, oriented ribbons] | Yes [tubes] |
Render Points | Yes | Yes | Yes |
Viewport Render | Yes | Yes | Yes |
Render View | Yes | Solaris Viewport/Render Gallery | Solaris Viewport/Render Gallery |
Interactive Mplay | Yes | Yes | Yes [No click to render] |
Render Snapshot Gallery | Yes | Yes | Yes |
Render to Disk | Yes | Yes | Yes |
HQueue - Distributed Rendering | Yes | Yes | Yes |
Standalone Command-line render | Yes | Yes via Husk | Yes via Husk |
CheckPointing | Yes | Yes via Husk | No |
VEX FUNCTIONS | | | |
- gather loops | Yes | Simple Trace (no shading) | No |
- illuminance loops | Yes | Never will be supported | No |
- trace | Yes | Simple trace function (no shading) | No |
Path Guiding | No | Yes | No |
Frustrum VBDs | No | Yes | Yes |
Light Shaping | Yes | Yes | Yes |
Per Instance Property Overrides | Yes | Yes | No |
