What tools are used for Houdini licensing?
The licensing tools for Houdini are:
hkey: A graphical licensing tool for managing licenses. Also known as License Administrator.
sesictrl: The non-graphical "hkey". Use this to perform license operations in the terminal shell.
sesinetd: The license server daemon/service.
hserver: The client helper program that acquires licenses by communicating with sesinetd.The location of licensing tools:
Windows For version 19 and higher:
- hkey: C:\Program Files\Side Effects Software\Houdini20.5.xxx\bin
- hserver: C:\Program Files\Side Effects Software\Houdini Server
- sesinetd, sesictrl: C:\Program Files\Side Effects Software\License Server
sesinetd.options needs to be set in this directory.
Prior to version 19
- hkey, sesictrl: C:\Program Files\Side Effects Software\Houdini 18.5.xxx\bin
- sesinetd, hserver: C:\Windows\system32
Linux
- hkey, hserver: /opt/hfs20.5.xxx/bin
- sesinetd, sesictrl: /opt/hfs20.5.xxx/houdini/sbin
Mac:
- hkey, hserver: /Applications/Houdini/Houdini20.5.xxx/Frameworks/Houdini.framework/Versions/Current/Resources/bin
- sesinetd, sesictrl: /Applications/Houdini/Houdini20.5.xxx/Frameworks/Houdini.framework/Versions/Current/Resources/houdini/sbin
The License Administrator (hkey) is the easiest way to install or manage Houdini licenses.
