FBX shader does not recognize alpha channel
   2354   3   1
Hello
i have imported a fbx model with textures but i have an error on fbx surface shader node in OGL alpha .
OGL alpha parameters : clamp(ch('opacityr')*ch('opacity_mult'),.1,1)
and in the next node “suboutput” i get this error :
channel evaluation error
traceback (most recent call last)
file “<stdin>”, line 1, in <module>
name error : name ‘clamp’ is not defined
thank you.
It looks like the expression language on your parameter is set to Python instead of Hscript.
Yes ! exactly ! thank you very much
Now my error is fixed but still no clipping . i have a tga picture with alpha in the tab 1 as diffuse . have to add a b&w pic as opacity ?
