im creating a while loop in vop sop inside of dopnet, setting condition value to 1, true.
for now its cooking about 20 mins and still nothing.
in tutorial there was no cooking op.
cooking op: torus/dopnet1/sopsolver/vopsop1 - executing vex - running vex code.
what am i doing wrong?
while loop cooking forever
4697 5 0- qbick
- 102 posts
- neil_math_comp
- 1743 posts
It may be useful to familiarize yourself with how a while loop generally works [en.wikipedia.org]. While loops will continue looping until either the condition value is 0 (false) or you explicitly break out of the loop. With a condition of 1 and no breaks, a while loop loops forever. Hopefully that clears things up!
- qbick
- 102 posts
ndicksonthank you
- edward
- 7899 posts
ndickson
I'm disappointed that there's no example on that wiki page for VEX or VOPs.
- asnowcappedromance
- 512 posts
I actually ran into the same problem a few days ago, but my while loop was setup correctly, meaning I had a condition which would break the loop at some point, but Hou would get stuck while executing the vex code.
Well after lots of doublechecking I finally found out it was my 3D viewport which froze Houdini, try switching it from GL to Hou11 or to another GL version, if you're while loop is set up neatly maybe this will do the trick.
best,
Manu
best,
Manu
- animatrix_
- 4729 posts
edwardndickson
Now there is
