Hi.
i'm doing a lot of tests with RBD objects.,
my question is how do i clear or delete my simulation from the object,
so i can do the test's again without loading my clear scene again…?
thank's
How clear RBD from an object?
2851 3 1- bar605
- asnowcappedromance
- 512 posts
- bar605
- RudiNieuwenhuis
- 193 posts
If you used the shelf tool to make an object a RBD object you can remove it from the simulation simply by removing the rest1 and dopimport1 nodes from the object. After that, you will have to remove the object in the Autodopnetwork as well.
As far as i know there is no shelf button to “remove object from simulation”
Is this what you meant?
